00' TB Wont run
Old Aug 1, 2005 | 04:28 PM
Steve6291's Avatar
Default 00' TB Wont run
It ran great for the first three months that I had it then it just stopped it will turn over by pulling it but solinoid just clicks.If I let it sit for 5 or 10 min pull it over it starts up then as soon as it comes to an idle it shuts off .I checked for spark no spark.I let it sit for 5 or so min again then check for spark it has spark but by the third time I pull it over it goes away I'm positive it has something to do with electrical,I've just run out of thing to think of..
Old Aug 1, 2005 | 04:55 PM
Halffast's Avatar
My best WAG would be that the charging system is not working. The battery builds up a small surface charge and it will run for a few minutes before it goes flat again. Try charging the battery and see if it works for longer than a few minutes. If so, then the charging system is the problem.
Good luck,
David
