trx450r vs what cannondale
Old Aug 2, 2005 | 08:02 PM
jrofrommaine's Avatar
Default trx450r vs what cannondale
what cannondale would be the best match up to keep up with the 450r.
also can someone post specs of the cannondale.
thanx
Old Aug 2, 2005 | 11:27 PM
atkrider's Avatar
what stock cannondale could not beat a stock 450r.
Old Aug 3, 2005 | 12:14 AM
Sandgod's Avatar
A Cannibal which is the low end Dale would probably edge out A 450R. Both machines are pretty corked up. The 450r has better front shocks, but the rear doesn't hold a candle so there are trade offs to each machine in respective areas.. The Dale would probably win in an mx race. It sits lower and handles better.. 450r frames break, C-Dale motors break and the Dales have more problems in general then a 450r..
Old Aug 3, 2005 | 12:56 AM
WISTECH's Avatar
I think a 450r would be a good match for a stock cannibal with the base round canister exhaust. We were checking out some dyno sheets last week and there was a 450r in the list at 42hp . It had a ported head ,carb ,cams,exhaust. Thats about equal to a stock dale engine with the airbox mod and aftermarket pipe. Ill see if I can dig up the sheets for greater detail.
Old Aug 13, 2005 | 10:24 PM
cannondale27's Avatar
Uhm I personallly dragged a 450r with HRC kit with a bone stock Dale stock toaster,stock map,stock gearing,stocktires and consistently beat the guy even when he started in front a little.But yes the front suspension is a nicer ride on 450R.
Old Aug 13, 2005 | 10:28 PM
oldsandman's Avatar
38-42 is right for a cam, and piped 450R. Add a ported head and 13.5 piston to that you're 44-46 hp 32#'s torque. Unfortunatly I never have been able to dyno my dale or any other on the same dyno to compare those #'s with.
Old Aug 15, 2005 | 05:01 AM
TheNadine's Avatar
I think all the dales could run a 450R, its a SOHC
Old Aug 15, 2005 | 10:22 PM
spoRtRax450R's Avatar
o ok because its JUST an sohc we can all rule out that it can possibly be faster[img]i/expressions/face-icon-small-confused.gif[/img] 450r frames break? thats why farr dosent even have gussets on his right...
Old Aug 16, 2005 | 12:34 AM
TheNadine's Avatar
450r dont stand a chance, i just dont like the SOHC setup, what can i say?
Old Aug 16, 2005 | 12:46 AM
WISTECH's Avatar
Honda designed them to be slower for a reason. If they just threw the crf motor in them they would be blowing chunks even faster than they are now.
