Scrammy 500 Relay Shot?
Old Aug 3, 2005 | 03:24 PM
PooNanny's Avatar
Default Scrammy 500 Relay Shot?
My diagnosis has led me to the relay/solenoid, but I'm looking for confirmation. If I turn on the ignition, the neutral light will oscillate with no particular pattern between on with full strength and about half-lit. Same goes for the headlights and tail-lights if I start the machine by shorting past the relay. If I try to start normally, the relay makes a lot of buzzing and clicking noises, but no crank. There seems to be a ground fault in the relay, but not a full ground fault because the machine doesn't die and the electrical system doesn't totally croak.
Am I overlooking something? Is this a known issue? Am I looking in the right place?
Thanks!
Matt
Old Aug 3, 2005 | 06:00 PM
scramblerXrated's Avatar
remove and fully charge your battery and test it to make sure its up to full capacity.
X
Old Aug 4, 2005 | 02:57 PM
PooNanny's Avatar
Put it on the charger when it wouldn't fire right away. Battery was completely up to snuff...
Old Aug 5, 2005 | 04:20 AM
jimmypsp700's Avatar
Try putting power directly to the starter.
If you need to get a new solenoid a lawn tractor one for $14 will work, do a search Big Bad Scrambler had the part #.
Jim
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Sep 15, 2015 02:42 AM
mbriggs
Sep 13, 2015 10:47 AM
cornermike
Jul 8, 2015 11:44 PM
