what are benefits of billet head over milled stock for 400?
Old Aug 5, 2005 | 08:43 PM
rieds's Avatar
Default what are benefits of billet head over milled stock for 400?
what is the difference between a billet head and a milled stock head? can you go higher on your compression with the billet head?
Old Aug 6, 2005 | 01:02 AM
fishslab's Avatar
Here is what I understand. The billet gives you options of different domes for different compression ratios. The billet uses a compressed O ring to seal out the water passages. The billet transfers heat and water better.
Old Aug 6, 2005 | 01:13 AM
duneaholic's Avatar
Yeah what fish said.[img]i/expressions/face-icon-small-tongue.gif[/img]
Bubba297's Avatar
Yep, what he said[img]i/expressions/face-icon-small-happy.gif[/img]
The HPD head also gives you the option of running a girdle kit to help keep the cylinder squished down and from cracking on the front 2 base bolts.
Without a head gasket you have metal to metal contact and that transfers the heat better.
Old Aug 7, 2005 | 11:37 PM
EAB's Avatar
EAB
Is the o-ring setup pretty reliable against coolant leaks?
Old Aug 8, 2005 | 12:27 AM
Whitedog's Avatar
Im gona speak from my own personal experience here... dont mill the stock head unless you girdle it.
my 2c.
Old Aug 8, 2005 | 09:19 AM
CED's Avatar
CED
I have never had any problems with the o-rings leaking.You need to use some grease to hold them in place ,when you install the head.
Old Aug 8, 2005 | 09:49 AM
POLARISFREAK's Avatar
I agree with what everone has said. I did have mine leak one time, it was blowing coolant out the overflow, but the orings had been in a long time. Changed them out and never had another problem.
Old Aug 8, 2005 | 06:00 PM
rieds's Avatar
how often do you have to change the o-rings. i'm not real fond of pulling the plastic and the gas tank to get at it. it would be nice if they started making these things with the gas tank out of the way so you can just pop open a door in the plastic and there's the head. haaaaagghh, fat chance of that huh, that would mean a hour of labor money lost.
Old Aug 8, 2005 | 06:28 PM
Bubba297's Avatar
If the surface is clean and the head is torqued, then o'rings should go at least a couple of years. the more compression and more rpms it turns the less life you will get out of them.
Dont use regular automotive grease to hold them in place. Petroleum will eat away at the rubber. The only preferred grease to use is di-electric grease. Not only is it a rubber lubricant, it also promotes heat transfer. I buy a small can, about 8-10oz with a tip like cheeze whiz. Just push it over to one side and it will ooze out a little. The can costs about $8 but will last a long time. That is also great for lubing up new seals and protecting anything rubber.
