How do I add headlights???
Old Oct 17, 2000 | 11:28 PM
will's Avatar
how do I add headlights so that they come on with the high beam switch can I just tapp in to the wires that come out the front to the 2 lights already there??? there are 3 wires which ones are hot and which ones are ground??? Also how do I hook up a back up light that comes on when I shift into reverse??
Old Oct 17, 2000 | 11:54 PM
dand11's Avatar
Will, Everything you ask about can be done. From the way you ask your questions it sounds like you need some local help not help through the mail. I added head lights and back up lights using the reverse switch. I used relays activated by the stock switches. The stock switches and wiring are not heavy enough to add exra equipment. A voltage tester and an underatanding of DC power will help you a lot.
Dan
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
