2 quicky questions
Old Aug 7, 2005 | 08:55 PM
alwaysride's Avatar
Default 2 quicky questions
Well, i had a great weekend of riding. I went to my families house in eastern kentucky in the mountains and rode about 150 miles of wonderfull trails. The only problem i had was that the belt light came on in the .35 sec intervals. I know that means the belt has wear so im just gonna get a new belt. When i change out the belt, will this light stop flashing or do i have to do a reset procedure. Also, my battery died this weekend and the wheeler wouldnt start. I got a new batter and everything worked fine but the winch stopped working.[img]i/expressions/face-icon-small-shocked.gif[/img]. IS there a fuse or somthing that might have went that caused this to happen. thanks
Old Aug 8, 2005 | 12:39 AM
trailblazermudrunner's Avatar
i know theres a reset thinggy you have to do but im not sure how to do it but check and make suer that all the power coard and fuses are all still connected and if they are try to loosen the 2 bolts on the on the winch and then tightn them and try it agin hope this helps
Old Aug 8, 2005 | 01:16 AM
alwaysride's Avatar
i know the regular procedure for like the 100 hour mark but didnt know if this one would be different.
Old Aug 8, 2005 | 05:47 AM
oh ok well could you tell me how to reset it for the 100 hours
Old Aug 8, 2005 | 11:53 AM
alwaysride's Avatar
turn off your key, there are a black and grey 5 pin connectors right under your shift lever. Take them both apart and put them to their opposite color. Black on grey, grey on black. There is also a little 2 pin connector. pull that apart also. Once you have the colors switched, turn your key on for about 10 sec, let it blink. turn your key off and let the bike go through its normol procedures of blinking and buzzing. Once that is done, put the black and grey wires back to their right colors and plug up the 2 pin connector. after this is done the light should be off. any more question because it made sound confusing, just ask.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
