check belt light
Old Aug 7, 2005 | 11:10 PM
trailblazermudrunner's Avatar
Default check belt light
hey my check belt light came on to day and i looked at the belt it was fine and i went for a 30 mile ride to day with no problems and any time befor this i was told thayt when that light comes on that they need to be survised and i was wournding what do you do to make the light go out after the survice
Old Aug 7, 2005 | 11:24 PM
HELP
Old Aug 8, 2005 | 12:04 AM
mudblaster's Avatar
on my 700 prairie it comes on at 100 hrs.
and that means its time to check the belt and change the oil.
after you have done that you reset it and its good for another 100 hrs.
but im not sure what kind of quad yours is because you dident say.
but thats probly what the light means its time to service it.
mine came on when 5 minutes after i went out last week and i put about 60 miles on it befor i got home and checked it.
i changed the oil and checked the belt and reset the light and i was back in buisness.
Old Aug 8, 2005 | 12:07 AM
i got the p 360 ok i know that much that now it need a oil change and all that good stuff so how do you rest the light?
Old Aug 8, 2005 | 03:43 PM
help
Old Aug 8, 2005 | 10:44 PM
HELP ASAP BEFOR I TAKE IT TO THE SHOP AND WAST MONEY FOR SOME THING I CAN DO MY SELF
Old Aug 9, 2005 | 02:47 AM
[img]i/expressions/face-icon-small-mad.gif[/img]
Old Aug 9, 2005 | 02:49 AM
WVHillbillyWTF's Avatar
is it a 650 or 700?
Old Aug 9, 2005 | 02:56 AM
not even close it a 360
Old Aug 9, 2005 | 03:20 AM
This is for a 650-700 Prairie. I don't know if it will work on a 360. I hope it works for you.
Make sure the belt switch in the ON position. Locate these connectors: Behind the plastic just below the shifter and forward of the fuel petcock a gray 4 pin connector and a black 4 pin connector. These connectors are held up by 2 flexible metal clamps. Unbend the clamps and pull the wires down where you can get to them easily. There is a black rectangular box on top of the CVT cover. This is the belt trip switch. There is a wire coming out of it with a black 2 pin connector attached.
This is straight from the manual in layman’s terms.
1. Make sure the ignition is OFF.
2. Unhook the black and gray 4 pin connectors. Hook black to gray and gray to black.
3. Turn the ignition ON.
4. Unhook the black 2 pin connector coming from the belt trip switch.
5. Let the belt light flash for at least 5 seconds. More than 5 seconds is OK.
6. Turn OFF the ignition and wait a few seconds to let the KEBC do its thing.
7. Turn the ignition back ON.
8. Let the belt light flash for at least 5 seconds. More than 5 seconds is OK.
9. Turn the ignition switch back OFF.
10. Reconnect the black 2 pin connector, disconnect the mismatched black and gray 4 pin connectors, reconnect the 4 pins to their proper mates.
11. Turn the ignition ON. The belt light should not be blinking.
12. Stow the wires back under the clamps and bend them to secure the wires.
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
