Predator Valve adjustment!!!
Old Aug 8, 2005 | 04:59 PM
XShowtimeX's Avatar
Default Predator Valve adjustment!!!
I just bought my predator about a week ago. The salesman couldn't find the valve adjustment in the book anywhere. I was just wondering how often you have 2 check the valves on it????? and if its pretty easy 2 do it yourself.
Old Aug 9, 2005 | 11:12 AM
Speedwerx's Avatar
Once your quad is broke in it would be a good idea to check them on your first oil change, 70% of pred. owners probably haven't done this though but the specs are as follows intake valves .006" exhaust valves .010" this is with a cold motor.
Old Aug 9, 2005 | 11:13 AM
Speedwerx's Avatar
+/- .0019" sorry
Old Aug 9, 2005 | 02:48 PM
XShowtimeX's Avatar
does it require a new gasket eveytime i check them. also what should i use to check the valves??? a caliper???
Old Aug 9, 2005 | 03:25 PM
Speedwerx's Avatar
If you have not done this before or seen it done before you should get a service manual to start off and then find someone with some experianc to help you other wise take it to the dealer or local shop otherwise you are going to end up spending more $ in the long run.
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
