HL ICM/Moose Module
Old Aug 8, 2005 | 10:33 PM
Hotrodbanshee's Avatar
Default HL ICM/Moose Module
Which is better the HL ICM or the moose module for BF750? Is there any difference in power? I have $100 to spend. I can get the HL for $93.95 or the moose module for $79.95. Anybody know much about these? Thanks
Old Aug 9, 2005 | 01:02 AM
GoatManx's Avatar
They all do the exact same thing ones no different from the other in performance except the moose module is plug and play the other 2 require soldering.
Old Aug 9, 2005 | 01:18 AM
1361's Avatar
Are these the same things as the Dana thing I keep reading about?
Old Aug 9, 2005 | 02:44 AM
WVHillbillyWTF's Avatar
No, the DYNA thing is an aftermarket CDI. It changes the timing curve through the entire RPM range, besides doing other things.
Old Aug 9, 2005 | 10:10 AM
tuffEnuf's Avatar
Dyna or VDI CDI will be cheaper & more performance in long run. CDI is Plug & Play in case you need to take it to the dealer for warranty.
By the time you get the Module + Flywheel Key + gaskets + labor you spend about the same. [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] Your choice. Be sure your Flywheel Key is installed correctly and Flywheel torqued to specs. Broken Keys could cause your machine to jump time, crank damage, and or TNT your Motor.
Old Aug 9, 2005 | 02:00 PM
DonEX400's Avatar
Do any of these plug in modules change anything besides the timing?
Do any of them have the fans turn on sooner for a cooler running quad?
Where can you get the moose for 79.00????
I have a 2005 BF 650 and am thinking of a module.
Old Aug 9, 2005 | 05:24 PM
FASTFATBOY's Avatar
The dyna changes the timing curve through the entire powerband. It also increases the spark energy, removes the reverse limiter and belt warning light. The dyna also, I believe but could be mistaken, increases the rev limiter a little.
Old Aug 10, 2005 | 02:41 PM
BRT's Avatar
BRT
Put a Moose module on the new 650.
Just made the rsponse quicker off idle.
Top end is still 69 mph.
Temp stayed the same also. Of course it has been 95 F plus out here .
Old Aug 10, 2005 | 03:32 PM
DonEX400's Avatar
where can I find one for 79 like posted in this post???
Old Aug 10, 2005 | 05:04 PM
BRT's Avatar
BRT
I got mine at theoutdoorshopinc.com.
88 bucks I believe.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
bbertram
Aug 28, 2003 06:13 PM
alltoys
Aug 6, 2003 04:32 PM
bfb750BF
May 26, 2003 01:52 PM
