weight chart
Old Aug 9, 2005 | 10:15 PM
baxy's Avatar
Default weight chart
does anyone have a polaris clutch weight chart?
or do you know what
16 - weigh
and
F - weigh
Old Aug 9, 2005 | 11:57 PM
baxy's Avatar
ok how about the width of a stock new belt??
as well
is there a washer under the primary clutch bolt which pushes on the outer shiv to decrease belt clearance because I have way too much with a realativly new belt
(less than 5 rides) and I have more side clearance than spider shim ... there is only one shim and it looks like maybe .020" and I have at least .050 to .060 clearance
once when I was working on the clutches I vaugly remeber switching the washer under the bolt for some reason???
Old Aug 10, 2005 | 05:09 AM
jimmypsp700's Avatar
Stock belt width is 1.188", low use limit is 1.125".
There is a resent post on the spring weights do a search.
Jim
blueandy88
Sep 7, 2020 03:11 PM
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
