Brute sunk totally....steps to flush?
Old Aug 10, 2005 | 10:56 AM
youthguymbc's Avatar
Default Brute sunk totally....steps to flush?
10 feet....5 minutes under. What are all the areas that must be flushed?....Gas tank?.....help!
Old Aug 10, 2005 | 11:27 AM
kawasaskirules's Avatar
mostly all fluids..even gas...clutch take the spark plug out and pull start if a couple....etc other guys will tell you more things to do
Old Aug 10, 2005 | 12:42 PM
tuffEnuf's Avatar
Youthguy
As soon as possible, drain oil/gas, Pull plugs. Inspect cylinder for mud (May have to flush out with hose) & use pull start to turn over engine/get all water out of cylinders.
Once all water is removed squirt cylinder with small squirt of oil and pull start again to coat cylinder wall and then remove pull starter housing, drain water, dry & reinstall.
Remove & Put battery on charger while you are cleaning Quad
Drain gastank, Remove drain blow out Muffler/exhausts, remove/clean carb bowls, slides, springs, jets & needle jets, and pilot jets, CVT cover. Use air source/blowgun and spray low pressure bursts of air in all jet openings near/in carbs and inside airbox & drain & blow out all drain lines/vaccum lines leading to airbox. Disconnect fuel line from petcock to gas tank and petcock to carbs
Thouroughly clean carb bowls, jets, remove/flush mud/dirt from inside CVT, belt, & clutches. Blow dry and inspect all fuses, wiring harness, slightly bend end on fuse, smear with diaelectric grease & Inspect/re-insert all fuses
Reassemble, Put in fresh gas, plugs, cheap oil/filter, & reconnect battery. Ensure CVT cover is installed before turning on key. Turn on key & let fuel pump out fuel line from tank, connect line to petcock and let full pump out line from petcock while cycling petcock. Reconnect carbs, full choke, engine kill switch off, and fire up. Run till fan kicks on and Change oil & filter. Repeat oil/filter change till no water is in oil put in favorite synthetic oil & good filter.
Buy a boat for water above 3 feet.
[img]i/expressions/face-icon-small-blush.gif[/img]
Happy trails
Old Aug 10, 2005 | 01:49 PM
ackademix's Avatar
how the helld ya do that one?? lol
Old Aug 10, 2005 | 04:35 PM
Thanks Man...The LCD was my worry, but is drying and gonna partly work. Lot's of work to a drowned rat........I'll check it all out tomorrow. 30 hours after happening. I changed oil on the river and got it out of the cylinders then as well.....thanks alot!
Old Aug 10, 2005 | 04:43 PM
Big brother didn't look close enough. Right off into 10 feet. I pull up to see 4 tires floating and three heads bobbing! I laughed. Until the LCD (probably $500) was shot. IT is partially working now though. I will check it out.
Old Aug 10, 2005 | 10:32 PM
sammydogs64's Avatar
How did you get it out of 10 feet of water in 5 minutes?
Old Aug 10, 2005 | 11:21 PM
easy, it floats upside down
Old Aug 10, 2005 | 11:22 PM
5 guys turn it over and pull it out
Old Aug 11, 2005 | 06:24 PM
trailblazermudrunner's Avatar
got pic *lol* well that sucks but if you deside to go doing that agin make sure you stay a little shlower like say about 4 feet lol but i think if you do the steps the thing will be rinning agin
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
