RPM range for Hetrick Pipe
Old Aug 11, 2005 | 12:26 PM
snowdust's Avatar
Default RPM range for Hetrick Pipe
Anyone know what RPM the hetrick pipe makes it's HP at? I emailed them and asked, but they never replied.
Old Aug 11, 2005 | 06:36 PM
sparky1698's Avatar
We noticed a change all the way around. I would call them instead. They are gone this week so maybe it will take a while for a e-mail reply. I talked to Robin there today so you might try to call tommorow.
Old Aug 11, 2005 | 10:50 PM
HQR109's Avatar
hopefully this link will work. it has the info you asked for.
dyno on pipes
Old Aug 12, 2005 | 11:45 AM
snowdust's Avatar
Thanks for the link. That was actually from a 50, but there was some interesting reading on there. I still can't figure out why a tach is not one of the first things installed when trying to tune these mini's. Even the articles didn't mention putting a tach on it. Although it did say the right way to dial them in is by HP @ peak RPM. Maybe most are not that serious about dailing them right in?
Old Aug 13, 2005 | 10:07 AM
Fastestdad's Avatar
Peak HP rpm depends on porting and how much air/fuel you can get in the engine. With a bigger carb like the 20mm instead of stock, peak HP will move to higher RPM. With a ported cyl it will go higher still. The dyno sheet is a bit misleading too cause those are old #s and it would make you think the technigas pipe was the most powerful but they do not work very well as the whole article stated.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
