trx450r oil capacity.
Old Aug 12, 2005 | 04:30 PM
offroadphotog's Avatar
Default trx450r oil capacity.
This is the first oil change. Anyone know how much oil it takes? I cant find my manual. There is two oil fill caps. One on each side of the engine. the left side has a round glass see through level with a high & low marking on it. There are no dipsticks. is one side tranny and the other oil? Please help thanks.
Old Aug 12, 2005 | 05:19 PM
Hondanutcase's Avatar
The side with the window is for the engine oil. It holds approx. .82 quarts of oil. Fill it to that capacity, start it, let it run a couple minutes, then let it sit a couple minutes. At this point the oil level should be at the high mark on the window. If its not add a lttle more. Careful not to overfill.
Old Aug 12, 2005 | 08:01 PM
right on, thanks a bunch!
Old Aug 12, 2005 | 08:06 PM
No problem!
I noticed that you said you lost yours. Did you take it out of the compartment under the seat. I just remember the dealer not telling me where it was. I assumed it was with all the paper work.
Old Aug 13, 2005 | 01:37 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The other side is trans oil. Do yourself a favor and run REAL transmission lube in there (just like you would run in the trans of a 2-stroke.....it's no different), instead of wimpy engine oil like you are forced to run in all the others where the trans and engine share the same oil. You are blessed to have the only quad where the engine and trans oil are seperate, so take advantage of it. My personal preference here is Maxima MTL. The trans holds 650 mL (cc), and its written on the case right below the full hole. Overfill it a little, take it for a short ride, then park it and open the check bolt and let the excess run out.
On the engine side, be sure to check your oil often. With so little oil in it, any leak or loss is critical! Change your oil and filter often, as well. My personal preference here is Maxima Ultra, ester synthetic oil.
Old Aug 15, 2005 | 05:58 PM
cals400ex's Avatar
i run maxima ultra in both sides. maybe the tranny side i should swap but it has served me well so far
Old Mar 16, 2006 | 02:30 PM
Jules's Avatar
Guys,
Just curious.. What happens if you overfill the engine and put let's say, 1 full qt. instead of .82?
01ssls1
Sep 22, 2015 06:50 AM
Aug 5, 2015 02:10 AM
yambam13
Jul 4, 2015 01:49 PM
dorene
Jun 5, 2015 05:25 PM
CyberTrip2003
Sep 12, 2003 10:53 PM
