lt80 chain / gearing
Old Aug 13, 2005 | 12:38 AM
Sandhopper2's Avatar
Default lt80 chain / gearing
I just got a project lt80 needs some work it's a 87 what did I expect
Chain is real loose and rear sprocket missing teeth stock size I think it is 26 rear and 17 front
I have seen adds for 10 front and 22 rear is this good or should I stay with stock ?
also I read to change to a #40 chain from the 520
help please I just want a play toy for my grandson he is only 5 , but going on 15
thanks for your help
the name sandhopper is from the short frame sandrail we use at Glamis it hops like a frog
Old Aug 13, 2005 | 12:03 PM
spike99's Avatar
Don't know the sprocket size or changing chain size questions you're asking. I wonder if your nearest Suzuki dealer can help with your "back to factory" questions??? Based on previous posts, I get the impression that many are pleased with their sprocket chain size and sprocket sizes / gearing of their LT80.
I do know that some LT80 folks like to install a fixed chain roller on the LT80s. This fixed roller reduces chain slack and thus, reduces faster wear on the chain. Also eliminates the need to use 1/2 links. For pictures how others installed a chain roller, surf:
http://community.webshots.com/photo/...85036639IpsrAA
http://community.webshots.com/photo/...85036888TsJRNc
Hope the idea of a fixed chain roller helps....
Old Aug 13, 2005 | 06:28 PM
duneaholic's Avatar
If you do go with a #40 chain then you will have to change out the sprockets to a 428 to make work with the chain. The 520 chain won't work. If you are just wanting something reliable then I would just go back to stock gearing. With the stock 520 chain and sprockets. The 428 sprockets and #40 chain won't last as long. You should be able to find this either thru your dealer or Rocky Mountain ATV.
Rocky Mountain ATV
This is a good place for Original stock equipment or "OEM".
Bike Bandit
Old Aug 14, 2005 | 06:18 AM
fishslab's Avatar
The only reason to get 428 sprockets and 40 chain is to be able to use halflinks in the #40 chain. Other wise just stick with the 520 chain and sprockets or if it's cheaper get the 428 chain and 428 sprockets. 428 chain is stronger than #40 chain. It does cost more, but if your not racing, it should last for some time. Use the chain roller ( i like the one that forces the chain more in a figure that looks like the letter B. It forces more of the chain against the teeth of sprockets.) and have fun.
Old Aug 14, 2005 | 01:59 PM
Rudedog's Avatar
Sprockets: Stock ratio is a 10 front and a 22 rear. I also agree that if the ATV's stock, I'd just buy the stock ratio stuff (520 size). Later if/when the little guy starts driving the dog shiz out of it, you probably will be doing a whole lot more to it IE: front & rear clutch mods, pipe Etc. At that time... you may want to switch to the 428 size gearing parts (less rotating weight). Also a chain roller setup is a good idea. If or when you do it, "slot" the plate. That way you'll have adjustablity should you want to change gear ratio's in the future.
Rude Dog
Old Aug 15, 2005 | 12:59 AM
I have heard the stock is 10 X 22 , but my early 87 yr lt80 has 17 X26
Will the 10 X 22 give me the same gearing and do I need an o ring chain ??
thanks for you help
Old Aug 15, 2005 | 01:13 AM
fishslab's Avatar
Yours is a little high geared, but i'm not sure if it made much of a performance difference. It would give up some bottom end for top speed. As long as the motor is still sound I would try to go back to stock gearing. At least you would be able to up the gearing as needed. I can't remember if ours had O ring chain or not, but if clearance was not an issue I would get O ring chain. Anybody know what the stock pitch was? I've got some new left over chain I'd give you if it's it's got enough pins. I got like 30 links left.
Old Aug 15, 2005 | 01:21 AM
so you are saying that 10X22 is a lower gearing , more bottom end , slower top speed ?
just what I'm after , don't need this thing going fast grandson is only 5
what is an o ring chain ??? and why do I want that
thanks
Old Aug 15, 2005 | 01:27 AM
fishslab's Avatar
Yes 10/22 would be lower geared. 2.2 :1 versus 1.53 :1. O ring chains have O rings in between the inner and outer side plates. This keeps dirt and moister out of the pins. They are pre-greased internally. This cut's down on noise, wear, and chain binding and kinking. You still lubricate the outside as neaded.
Old Aug 15, 2005 | 01:43 AM
spike99's Avatar
To view an O-Ring chain and how to install it, surf entire page of:
http://www.atving.com/atvconnection/.../techtip23.cfm
Note: Clearly seen O-Ring chain and its rubber O-rings are 3/4 down this page.
Hope this helps...
