Holeshot HD's
Old Aug 14, 2005 | 01:55 AM
Ricke's Avatar
Default Holeshot HD's
k this might sound stupid but where on the tire do it said how much air goes in, i know its on the side but all i can find is the pressure not to go over when setting the bead, someone help?!?!
Old Aug 14, 2005 | 10:59 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
They never give a recommended pressure. I usually run around 4 pounds in back, and 4.5. You will need to experimant a little though, to see what exact pressure if best for your terrain and riding style.
Old Aug 16, 2005 | 03:36 AM
cr125predator's Avatar
Yea, i also run 4-5 pounds. Just like reconranger said, you'll have to experiment a little bit.
Old Aug 17, 2005 | 04:04 AM
crashboyz's Avatar
I ussually run around 4 psi in the rear and 5 psi in the front. I get alot better tractiong running that low of pressure. i dont believe it says on the tire what to go to. I think it says on the bike itself
Old Aug 17, 2005 | 11:46 PM
Torbinx's Avatar
I know on my brothers honda 350 4x4 when setting the bead do not exceed 15psi. I myself would use around the same. As for tire pressure I would run around 4psi back and 5psi front. Guys above need to learn how to answer the mans full question. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Aug 21, 2005 | 01:26 AM
Dinger's Avatar
In my holeshot hd's I run about 1.75 in the rear and 2.5 to 3 in the front.
Old Aug 21, 2005 | 01:52 AM
Vunit's Avatar
4psi is perfect for the HD's...at least thats what i heard..but test everything out alittle and see what psi you like best...
Old Aug 21, 2005 | 10:54 AM
droz's Avatar
i used around 15 to set
for the riding i do i run 4 psi in the front and 3 in the rear
if i get somewhere smoother and flatter i will bump it up a psi or 2 front and rear and i always run more in the front then the rear
Old Aug 30, 2005 | 12:05 AM
Vunit's Avatar
i just got my razr 2's and they were mounted on douglas red lables and balenced too when i got them and they had 3psi in the rear...so i left that and in the front im running 5psi...i would guess its good if they balenced them for me???
MikeyBoyesq
Nov 27, 2020 02:44 PM
STLyamwar
Jul 25, 2020 04:44 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
jeepin
Aug 3, 2000 10:01 AM
Rob4092
13
May 2, 2000 12:01 AM
