Why wont it work. please help.
Ok, here how it all started. I was riding last week and i had came back to the cabin. WE needed to move the prairie to get the horses out and my buddy said it wont start. THat ended up to be just the battery and it was fixed. But since then, my winch has not worked. Why is this. Is there a fuse bad. Thats is my guess or a corroded conection maybe. Were is the fuse located on my warn 2.5 winch. The cylinoid for it is in the back tool box. Help please. thanks.
Fuses are under seat.
I'd First start with inspecting wiring from battery to solenoid and insure all connections are tight. Isolate solenoid and run direct line to Winch motor to rule out rocker/solenoid. Be sure enough cable is out so you don't bend up something.
Look at your winch wiring instructions and double check wiring.
