Need help with Mojave Starting!
Old Aug 14, 2005 | 10:13 PM
dnkrm's Avatar
Default Need help with Mojave Starting!
Hey, I have a 2001 Mojave, i have the factory replacement k@n filter with a dg supertrapp pipe. I always had a weak spot in mid range power and it would run better with the choke on so I knew I was running lean. I finally decided to take it apart and jet it and I decided to get a carb rebuild kit as well since it didn't cost too much and my float valve looked pretty bad. Anyway, i put the kit in and went with a 138 jet to start with. So far I have not been able to get it to start without pulling it. Once I pull it it will run pretty good (i think it is rich so i might go to a 135) but if i let it sit for a few minutes it still won't start by just kicking it. It sounds like it is really close but won't fire. I put in a new spark plug and that didn't seem to help any. let me know if you have any ideas. thanks
Old Aug 14, 2005 | 11:54 PM
tuffEnuf's Avatar
some members have posted that out of adjustment valves will make it hard to start. Also try a fresh/hot battery and double check battery leads for tightness and corrosion.
Old Aug 15, 2005 | 12:01 AM
dnkrm's Avatar
i can only wish i had a battery (kick start), if I had electric start I might want to keep it but once i get it running right I am ready to get something different. As for the valves I will have to look into that, thanks for the info. later
Old Aug 15, 2005 | 12:31 AM
tuffEnuf's Avatar
DNKrm
Contact Greg at CWR racing (cycleworksracing) look up on internet or contact/email him at greg@cycleworksracing.com
He's the "GURU" on the Mojave
Old Aug 15, 2005 | 10:21 PM
kwackermann's Avatar
What did the plug that you took out look like?
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
Reconrider
Aug 30, 1999 02:17 PM
dunc_n
Aug 26, 1999 09:32 PM
RidE
Aug 6, 1999 02:34 PM
