01 Honda Recon with no fire
Old Aug 16, 2005 | 10:08 AM
tburleson's Avatar
Default 01 Honda Recon with no fire
I have a 2001 Recon that stopped running one day. I wasn't getting any fire. I replaced the plug and still no fire. I checked the coil it's ok. I even replaced the cdi module and still no fire. There's a fuse under the seat, it's okay too. What else could it be? Any help would be greatly appreciated!!
Old Aug 16, 2005 | 01:50 PM
hondabuster's Avatar
Kill switch, key switch....bad battery or connections,
Old Aug 16, 2005 | 02:28 PM
tburleson's Avatar
If the key switch or battery was bad would the starter still work? How can I check the kill switch?
Old Aug 16, 2005 | 02:51 PM
ixRAZORxi's Avatar
They corrode and ground out. Take it apart and try bypassing it or check it with a multimeter for continuity
I bought a lawnmower like this once for 20 bucks. I sold it for 500 after I put a new switch in it.
Old Aug 16, 2005 | 04:07 PM
I think theres more than one fuse...are they all good?
The kill switch will still allow starter operation, but wont let spark happen.
Do you have a nuetral light?
What were the circumstances of it not running? You just parked it, and now it wont fire? Did it get swamped?
How did you check for spark? Holding the plug against the head, and spinning it over, and looking for spark?
Old Aug 17, 2005 | 08:57 AM
tburleson's Avatar
I only found one fuse I'll keep looking for another one. Yes I have a neutral light and it is on while I'm trying to start the engine. When my recon died I was riding in a grass field in 2nd gear. I was just putting along and it cut off. I don't ride this atv in the mud or water. It stays in the yard or the field mostly. So theres no corrosion on any connections that I can see. To check for spark I put the plug onto the head and looked for a spark. Where would the kill switch be located on the recon?
Old Aug 17, 2005 | 11:08 AM
recon99's Avatar
The kill switch is the red switch above the starter button, but with recons if the motor cranks then the kill switch has to be in the run position. There is only one fuse on a recon, which is required for the motor to even crank. I would start by checking for bad wiring around the cdi and work your way front there's probably a wire that got pinched or broke.
Old Aug 19, 2005 | 08:48 AM
tburleson's Avatar
Problem solved! Its a pinched wire. Thanks for all the great advice!
Old Jul 12, 2017 | 08:16 PM
Mike Kinder's Avatar
Where was the pinched wire? I have a recon same symptoms and happened while riding.
Aug 5, 2015 02:10 AM
cornermike
Jul 30, 2015 06:37 AM
toonces
Jul 24, 2015 09:03 AM
Jul 22, 2015 05:00 AM
MNatv89
Jul 7, 2015 11:36 AM
