best raptor gearing for dunes?????
Old Aug 17, 2005 | 12:42 AM
10klt250r's Avatar
Default best raptor gearing for dunes?????
with just pipe,jet kit and K&N?.......and whats the difference between changing the front as apposed to the rear?
Old Aug 17, 2005 | 01:16 AM
diirk's Avatar
Make is easy on yourself and drop one tooth on the front.
FYI, one front tooth equals 3 rear teeth.
Old Aug 17, 2005 | 01:20 AM
CHEVZ7194's Avatar
With the setup you got right now I would drop one tooth on the front. You will notice a big difference in the bottom end power and torque. I really didnt notice to much difference on the top end. 1st gear is very very low. 2nd and 3rd are great for beasting up those dunes.
Old Aug 17, 2005 | 01:27 AM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
with 22" rears i run 12 up front and 42 in the back. seems to do pretty good in the sand. well i just run that everywhere now. i used to run 12x44 for trails but im to lazy to change sprokets all the time.
Old Aug 17, 2005 | 10:14 AM
HappaRap's Avatar
Lazy Boy Rider!
Just remember, changing the front means the sprocket will wear out faster than if you were to change out the rear, if you ride trails changing out the rear will require you to shim the skidplate if you run one. Dropping one tooth up front is equal to 2.75 on the rear, I run 22's 12/42, that's a great all around combination, tried 12/44 but 1st was pretty much worthless. It really depends on what tires you're running also, 22's require lower gearing, 20's don't require as low. Changing out a front sprocket is much easier than the rear and you don't have to worry about shiming that skidplate.
Old Aug 17, 2005 | 10:31 PM
CTracingraptor's Avatar
i run 22's amd i love my 13/44 its the preferred ratio for racing on 22's.
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 9, 2015 05:58 PM
