Are the HPD engine mounts the same as the polaris oem?
Old Aug 17, 2005 | 01:23 AM
ScramaDamaDingDong's Avatar
Default Are the HPD engine mounts the same as the polaris oem?
they look the same to me anybody have any more info
Old Aug 17, 2005 | 09:13 AM
POLARISFREAK's Avatar
The hpd are a harder rubber.
Old Aug 17, 2005 | 10:15 AM
duneaholic's Avatar
I like mine. After I got my HPD mounts on the gas quit leaking out of the bowl vent on the carb so much (bouncy bouncy from the paddles). Weird I know.
Old Aug 17, 2005 | 12:00 PM
conig's Avatar
I was wondering if they would stop the fuel slosh. The 400 motor shakes around like crazy.
Old Aug 17, 2005 | 02:34 PM
mine bounced around a lot too and while I was tearing my engine apart I found out why. the top motor mount didn't have a nut on one side. Guess the guy that had it before me forgot that nut. on the other hand sometimes you feel like a nut sometimes you don't.
Old Aug 17, 2005 | 06:21 PM
scramblered's Avatar
no,not the same compound at all especially if you go for the 90 durometer
or more,even on sleds polaris put very weak motor mounts,you need to go
aftermarket and that is simple like this,on a modded engine the stock mounts just can't hold the engine and that is the worse thing,they wear out pretty quick.
neilbedwell
Nov 10, 2018 11:02 AM
NewHillBilly
Jun 14, 2015 11:42 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
