05 700carb top rpm?
Speedwerx, The only thing I've done to the machine is put 1 inch taller tires, however, they are as light as the stock tires. I want just a little more engagement, but not too high. I changed the primary spring in my wifes trailblazer and it made a noticeable difference, so now I want the same. thanks
When, your quad had the stk. tires did it bounce off of the rev limiter? We would run our green primary spring with a set of i-56's or j-1's when you out the larger tires on it just like gearing your quad up. Do you car about top speed at all? Your secondary should be fine but if you continue to hit the rev limiter we will go with a softer secondary spring.
