>>>>wheelies<<<<
Old Aug 17, 2005 | 03:56 PM
dreamMACHINE's Avatar
Default >>>>wheelies<<<<
heya, this is mainly to the people who can wheelie a 660 raptor perfectly, how do you do it? what gear and what gear when you want to do one when you setting off. i have just got my raptor and i can wheelie it but i am not sure which gear? any help?
Old Aug 17, 2005 | 03:59 PM
660Rryder's Avatar
Stock? 1st, 2nd, 3rd. Piped (full system), 4th, maybe fifth depending on the conditions.
Old Aug 17, 2005 | 07:24 PM
Raptorman690's Avatar
On a stock 04' raptor that was my friends i could wheelie it 1st-5th. On mine, I can do the same, it just depends how agressive you want to be with it
Old Aug 17, 2005 | 07:53 PM
dunbarr's Avatar
start out and first and work ur way
Old Aug 17, 2005 | 09:54 PM
Storj's Avatar
start in first and work your way through the gears just dont hit the throttle to hard in the beggining or you will go backwards and land on your rump
Old Aug 18, 2005 | 12:01 AM
Muzzy's Avatar
I'm no pro at riding wheelies, but I've started to really get he hang of it. I started off by just popping the front end up in first, and getting used to knowing what it takes to get the front end up. Then get used to feathering the throttle once you get it up, then I started doing the same thing in 2nd. I think 2nd is the best, since it still comes up real easy, but you have more room for error than in 1st. Just be careful, 1st gear on a Raptor will put you on your back in a hurry.
Old Aug 18, 2005 | 12:31 AM
66003Raptor's Avatar
well said......lol
Old Aug 18, 2005 | 04:48 AM
thanks 4 replies, i shal try, i have had de quad on it back lol. i will see how it goes
Old Aug 18, 2005 | 05:05 AM
RaptorRookie's Avatar
I found that standing up, rather then sitting on the seat, helps me a bit. It seems I have a better feel of the balance point and I can see where I am headed better. However, if you should need to hit the break to keep from going over, that is a bit tricky. Now when I wheelie I sit down and can go till I run out of room. I have gone over plenty of times, and my grab bar is proof of that as it is bent up. It just takes practice and eventually you will feel the balance point. Once you get it, it is a beautiful thing. I like 3rd the best, first and second come up too fast and there is a greater chance of goin over. Eventually you will be able to shift throught the gears while keeping the front up.
-Brandon
Old Aug 18, 2005 | 06:06 PM
dragraptor's Avatar
well i first started on a hill in 1st,then i learned to ride them in all gears and shift gears in a wheelie, just keep practicing every time you ride.
