Just got an FX400
Old Aug 18, 2005 | 04:42 AM
zmann's Avatar
Default Just got an FX400
Any tips? I am sure I will need some parts once I get to tear into it. Should be a fun bike.
Old Sep 2, 2005 | 03:18 PM
kawiking's Avatar
go to suz or kawi!!! suz z400 will help u more than kawi site, all kinds of modds
Old Sep 2, 2005 | 04:59 PM
WISTECH's Avatar
fx400 or kfx400? Theres a slight difference.LOL
Old Sep 3, 2005 | 03:01 AM
zmann's Avatar
I am aware of the differences. It is an fx400.
Old Sep 3, 2005 | 07:59 PM
WISTECH's Avatar
If it still has the fx400 case then make sure to get the case converted to the newer style flywheel side crank bearing when you pull the engine for the rod bearing . Check the rear swingarm for cracks in the center section. other than that the updates are pretty much the same as the rest of the cannondale line.
Old Sep 4, 2005 | 12:17 AM
zmann's Avatar
ok, It needs a fuel pump. I was going to get it running first and then take it from there.
Old Sep 4, 2005 | 10:00 AM
DavidLT250S's Avatar
um sorry for asking but what is a FX400?
Old Sep 4, 2005 | 11:26 AM
WISTECH's Avatar
Its the first year Cannondale quad. Easy identified by thier smoke grey plastic with mini mudflap front fenders. If not for the extemely weak flywheel bearing I would consider them the most reliable cannondale ever to come from the factory. Although in stock form they have a way to agressive mapping for the stock chassis . I find them hard to drive safely because of the sensative throttle , narrow track width and the underleveraged steering stem.
Zman might want to check that fuel pump before replacing parts.
Old Sep 8, 2005 | 02:17 AM
zmann's Avatar
I have to since it doesn't have one on it. I was told that it was bad and that is why I got it so cheap.
Old Sep 9, 2005 | 07:54 PM
WISTECH's Avatar
Hard to check if its gone. LOL
blasterrider
KTM
Feb 24, 2006 10:14 AM
blasterrider
Feb 23, 2006 07:25 PM
hondaracer305
KTM
32
Nov 23, 2003 07:11 PM
meaniegreenie
KTM
12
Jun 3, 2002 10:57 PM
Yamahafan
May 2, 2001 11:40 AM
