can anyone help me with my trailblazer 400
Old Aug 19, 2005 | 03:38 AM
jman1's Avatar
Default can anyone help me with my trailblazer 400
hi. my trailblazer will not charge up the battery. I can still pull start it but the lights feed off the battery until its dead. even with it running the lights will not work if the battery is dead. I have replaced the battery and the magnet switch.I have looked all over for a wire that came off, the only thing I found is a wight clip under the black hood were the oil tank is that is not conected to anything but I cant find anything to connect it to. pleas can anyone help.
Old Aug 19, 2005 | 07:05 AM
POLARISFREAK's Avatar
More than likely your voltage regulator is out. It's the flat, thin black box under the front nose piece!
Old Aug 19, 2005 | 09:03 AM
cornbread2's Avatar
It could also be the stator.
Old Aug 19, 2005 | 10:16 AM
Bubba297's Avatar
Get a volt meter, set it to AC voltage and check the yellow and yellow/red tracer wires while running. Those are your AC input to the regulator if I remember correctly. If you have it (20-40 volts) then more than likely the regulator is out. If you dont have AC current then you either have a bad stator or a broke wire or bad connection.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
