wheelie with Rancher
Old Oct 20, 2000 | 07:17 AM
cndrancher's Avatar
Could not beleive this.
On take off I punched the throttle all the way in, pulled the handlebars back and the front wheels came off the ground.
I'm amazed. My Rancher is plain stock too.
Al Bertrand
Rancher 2000
Old Oct 20, 2000 | 10:31 AM
Rancher328's Avatar
It must not be a 4x4 Rancher.
Old Oct 20, 2000 | 05:05 PM
getoutofmyway's Avatar
I can do that also on my daughters Recon. It has more to do with weight distribution than power. My Warrior is much more front heavy and won't wheelie unless I dump the clutch. Both quads are stock.
Old Oct 20, 2000 | 07:10 PM
alaskaweasel's Avatar
My 4x4 will wheelie, if it's a 2x4 then it should be even easier.
Old Oct 20, 2000 | 08:04 PM
bzizzi's Avatar
I have both a 4x4 Rancher ES and a 2x4 Rancher ES and they will both wheelie very easy,although the 2x4 will stay up longer.
Old Oct 20, 2000 | 11:54 PM
Rancher328's Avatar
Hum........ My Rancher 4x4 will get off the ground but it usually takes a little bump on the trail, and all the throttle I can give it not to mention a good yank. But then again, I'm running 26" TSL's so that may be the difference.
Old Oct 21, 2000 | 02:42 AM
cartman308's Avatar
my rancher will wheelie also. it's a 4x4 ES. you need to get the timing down between the throttle, shift, yank. I can wheelie pulling off in first, from first to second, and raise the front going into third
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
