PVT cover bolt torque
Old Aug 20, 2005 | 02:36 PM
jefffoxsr's Avatar
Default PVT cover bolt torque
In the service manual it says "PVT Inner Cover Bolts 12 ft. lbs."
So, I set the inch # torque wrench to 144 inch #'s. I couldn't get the bolt to that torque.
The spec must be lower. Anyone know what it is? Any thoughts?
Old Aug 20, 2005 | 06:10 PM
jefffoxsr's Avatar
I looked at the parts manual. That torque was for the inner cover, not the outer cover. They don't list the torque for the outer cover. Anyone know what it is?
Old Aug 20, 2005 | 07:57 PM
Kushman's Avatar
That is a heII of a queastion....I just looked in the maintenace manual....Did'nt see it anywhere.
I know they are course threaded screws. I have a knack for that kind of thing and its not a problem.....
somebody that knows will chime in here
Old Aug 20, 2005 | 08:05 PM
GE4x4's Avatar
There is no set torque for the outer cover. I just alternate and tighten to what I feel is good. A good snug fit should be fine.
Old Aug 20, 2005 | 08:59 PM
jefffoxsr's Avatar
I just usually go around the cover a few times and make sure they are snug. Always the perfectionist.
GE4x4, I can't wait until you get a long test ride on the new outlander so you can tell us how it compares to the sp800.
I noticed in the manual that it says to periodically drain the recoil housing. That bolt is not in an easy area to get to. Is it really necessary? I don't go in much water, but the manual said moisture will build up in there.
Thanks.
Old Aug 22, 2005 | 04:05 AM
jimmypsp700's Avatar
Like GE4x4 said, just snug them up, do not over torque them.
Jim
1ArmBandit
55
Oct 14, 2015 09:03 PM
Canamaniac!
Sep 15, 2015 06:19 PM
carid
Sep 14, 2015 03:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
