700SP Clutch Issues
Old Aug 20, 2005 | 02:58 PM
DamnYankee's Avatar
Default 700SP Clutch Issues
2004 700SP developed a hard sifting problem at approximately 400 miles. Seemed to be more pronouced when ever the bike was in a bind. Finally got to the point where it you had to shut it off to shift. Paid $140 for the stealer to shim the clutch (14 days out of warranty !).....explaination was the motor mounts sagged causing the clutches to become missaligned. Shifting 100% better after the fix, except when the bike got hot, then the symptoms returned. The transmissions simply stays engaged when the bike is stopped. Sometimes, you can free the clutches by severely rocking the machine back and forth. Back to the delaer, and apparently Polaris says "keep shimming"
Anyone have a similiar experience?...... advise?
Old Aug 23, 2005 | 06:44 PM
425Xpedition's Avatar
Normally when the bikes start doing this the drive clutch is worn or grooved. Shimming the clutch is a band-aid and will work for awhile, but the problem will come back. The best way to fix the problem is to replace the clutch. A torn motor mount can cause this problem also, but not very often.
Old Aug 24, 2005 | 07:12 AM
jimmypsp700's Avatar
I know this is just simple but a stab at it non the less....
Does it creep forward, if so your idel could be turned up too high.
Old Aug 27, 2005 | 01:26 PM
DamnYankee's Avatar
Thanks for you ideas.......... I've adjusted idle from 800 - 1200, makes no difference. I called the dealer I bought it from, he says hes never had an issue with a 700 clutch, which makes me curoius. Called the "stealer" this morning, he says 2 weeks before he can get the shims and to sit tight. Kinda getting the feeling that I'm getting the shaft
Old Aug 31, 2005 | 01:49 AM
firemedic5586's Avatar
How many miles are on it? Yes it could be your mounts shifting...polaris's do do that. If your handy you can do all that stuff yourself. http://www.hotseatperformance.com/ps...1929&CATID=261
http://www.hotseatperformance.com/ps...2503&CATID=261
Given the choice of buying tools or paying a dealer to do it..... I have the tools in my tool box. If by chance your drive clutch is toaste, that would give you the excuse to put in a clutch from a 800.
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
