clutching help!!
Old Aug 21, 2005 | 05:30 AM
scrambler123's Avatar
Default clutching help!!
my friend has a trailblazer that has lost a lot of top speed , he has done everyhting to try and fix it (rebuilt it, new belt, cleaned carb), i assume it has to be a problem with the cluthcing any ideas what it could be?
Old Aug 21, 2005 | 05:00 PM
lslubecki's Avatar
Maybe a worn belt?
Steve Lubecki
Old Aug 22, 2005 | 02:45 AM
it has a brand new belt
Old Aug 22, 2005 | 03:26 AM
jimmypsp700's Avatar
Full shift out, it should be at the top of the primary sheeves.
Check the weights.
JIm
Old Aug 22, 2005 | 05:49 AM
what could be wrong with the weights?
Old Aug 22, 2005 | 09:36 AM
CED's Avatar
CED
Make sure the distance between the 2 shafts are around 10".This is from center to center.
Old Aug 22, 2005 | 10:44 AM
scramblered's Avatar
gearing change?
helix?
Old Aug 22, 2005 | 01:57 PM
conig's Avatar
how about compression it seems to me if it was getting close to top end time and lossing compression it would get slower.
Old Aug 22, 2005 | 03:09 PM
theres 10" between the shafts, theres 1 1/3\2 inches of belt deflection, compression is good it was just rebuilt and tested
Old Aug 24, 2005 | 10:49 AM
lovemud's Avatar
It looks like you've got the clutch covered, and it was just rebuilt. I would focus on carb and engine timing.
