Drive belts explod!ing !!!
Old Aug 21, 2005 | 09:02 AM
casual's Avatar
Default Drive belts explod!ing !!!
My 700sp slightly modified eats the belt in about 150 miles , they completely dissintegrate. Can not seem to find a dealer for the daycohp belt. clutched,piped,cam and38tmx. Any suggestions ?
Old Aug 21, 2005 | 09:56 AM
scramblered's Avatar
a tmx 38 can fit on the 700?
that seem to be awsome to see fit in there,you may do some clutching
changes if the belt did wear out sooner,stiffen the secondary may be
an option too,but i'm not sure,use polaris belt,they provide longer
clutch lives.
Old Aug 21, 2005 | 09:57 AM
SPORTSMAN70003's Avatar
Sounds like somthing is out of line with your clutch or your not using low range when you should. Have you checked the clutch vents and made sure they are not stopped up? If the vents are stopped up it when generate alot hot heat and might cause the belt to do what its doing. You can get a Dayco belt at Advance auto parts that where I got mine.
Old Aug 21, 2005 | 08:44 PM
casual's Avatar
spotrsman70003. The only clutch vent I know about is the air snorkel on the clutch case. Am I missing somkething?
Old Aug 21, 2005 | 08:58 PM
You have a inlet which is # 11 here. You also have a outlet which is # 3 here. I hope this helps.
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
