scrambler cracked casing
Old Aug 21, 2005 | 06:19 PM
MOJAVEalltheway's Avatar
Default scrambler cracked casing
i went to look at a 1997 polaris scrambler that i was interested in buying , its in good shape all except for the pull start casing has a small hole in it, i dont know how the whole got there, but when i look in the whole i can see a gear, i believe its the flywheel but im not sure, i was just wondering if something fell into this whole would it travel though the rest of the bottom end of the motor or is this section seperate? need a response asap
Old Aug 21, 2005 | 06:29 PM
thewayout420's Avatar
its seperate,behind the recoil housing is the flywheel and the stator.nothing will get into the lower end of the motor if something was to fall into the hole but you still dont want anything falling into it seeing *** the flywheel weights and the stator would probably get damaged..
Old Aug 21, 2005 | 06:37 PM
yeah im going to patch the hole and make sure nothing is floating around inside there if i buy it
thanks alot
Old Aug 21, 2005 | 06:38 PM
let me know if you buy it,i have a used recoil housing that is in good shape except for the recoil itself needs to be rewound..
Old Aug 21, 2005 | 11:49 PM
Whitedog's Avatar
Hows that swinger holdin up?[img]i/expressions/face-icon-small-wink.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
WilliamBos
Sep 22, 2015 04:07 PM
