Quicker steering for FL 250 Odyssey?
Old Oct 20, 2000 | 04:15 PM
cheesehead's Avatar
Is there a "trick" method for making my FL 250 turn a little quicker? Thanks, Cheesehead
Old Oct 21, 2000 | 08:40 AM
400exalltheway's Avatar
well if its like my friends fl350 than i highly doubt it, cause to turn quicker you would have to be able to lean into the turns. if youur gonna run cirle track theres ways but you would set it up to turn one way sharper(usally counter-clocker wise)
Old Oct 21, 2000 | 08:23 PM
LiveWire's Avatar
You can trim the steering stops. Don't do too much or the tie rods will rub on the rims. If you modify it to have a rear suspension, you can also give the rear tires a little toe in. This will help turning. A swing axle style rear suspension is not that hard to set up.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Logan Collins
Sep 5, 2015 08:03 PM
