Kawi 300 4x4 valve lash
Old Aug 22, 2005 | 09:02 PM
bayouboy03's Avatar
Default Kawi 300 4x4 valve lash
My friend has a kawi 300 4x4. lately it has been making bad ticking noises from the top end. he has no manual does anyone know the valve lash on this quad? I am hoping that is all it is but deep down inside i think maybe stretched timing chain may be the issue. it has lost a lil power. it is a ticking sound not a knock.
Old Aug 22, 2005 | 10:33 PM
alisonsandmindysdad's Avatar
I don't have a manual for a 300 anymore, but you can go to www.buykawasaki.com. Go to "Owner Info" at the top of the page and then go to "parts diagrams". Once you find your year/model/etc. you will have an option of "specifications". It should be listed there. Is it a Bayou or a Prairie? (although I think the engines are similar)
Old Aug 23, 2005 | 06:19 PM
Mohawk's Avatar
The specs that you want are.
IN 0.10 ~ 0.15 mm
EX 0.15 ~ 0.20 mm
Old Aug 23, 2005 | 08:09 PM
bayouboy03's Avatar
thnx guys
Old Oct 26, 2008 | 09:28 PM
trott33's Avatar
Default Kawi 300 4x4 valve lash"></title><script src=
I had the same type of noise on mine. I did not take care of the problem and ended up breaking the tab on the cam gear. When it let loose it bent both valves.(lucky they did not go through the piston). I would recommend changing the timing chain very, very soon. My chain had severe strech.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
