New 700EFI Coolant Question
Old Aug 23, 2005 | 09:35 AM
Bytor's Avatar
Default New 700EFI Coolant Question
Just brought home my new 05 Sportsman 700EFI yesterday. The coolant level in the reserve was between min and max. Rode it around the neighborhood for a while and noticed the level in the reserve dropped quite a bit. Rode around some more and parked it. The reserve is now completely empty. Put a total of about 1 hour on it. Is this normal for a new 700EFI? Does the system generally have air in it when new? I have 2 SP400's and neither did this. Thanks for any help.
Old Aug 23, 2005 | 09:54 AM
Mudlover600Tw's Avatar
Take it back and get them to fix it there are alot of coolant isssues with the twins.
Old Aug 23, 2005 | 11:00 AM
ImABigBoyNow's Avatar
I had a similar problem. My 700 was actually leaking coolant all over the floor of my brand new garage floor. (I didnt even ride it yet) Needless to say, I was pretty pissed when I called the dealer. I made them make a house call to me all under warranty. It turns out there was a faulty clamp on a hose.
It did continue to leak slightly until I had a chance to put a few miles on it. I guess the seals need a little heat to seal properly.
Old Aug 23, 2005 | 11:34 AM
colt2245p's Avatar
the clamps are probably not tightened properly or it had a air pocket in the system i have seen both of the above several times at the dealer i work for hope this helps[img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 23, 2005 | 11:48 AM
Bytor's Avatar
I should have added that I have not seen any coolant that has leaked out. No puddles, no drips. That is why I was thinking that maybe the system had air in it that needed to be purged. Or was the radiator not filled up by the dealer. I'll be giving my dealer a call this afternoon.
Thanks for the replies.
Old Aug 24, 2005 | 08:11 AM
Wayback40's Avatar
Having seen this same problem in other new sportsman's that I have purchased I had the dealer add some extra coolant before I took my new 05 700efi home. The mechanic that added the coolant confirmed my thoughts and yours, the air needs to be purged out. I had to add more coolant at about the 100 mile mark to. Have close to 400 miles on her now without any further issues.
Old Aug 24, 2005 | 10:04 AM
Bytor's Avatar
Thanks Wayback. My dealer said that I may have to add 2 or 3 times. Found out last night that my neighbor, who has an 04.5 SP600, had to do the same. My 2 SP400's never did this so it concerned me. Maybe the twins are different? Anyway, thanks, makes me feel better knowing others have seen the same thing.
shimanok2
Jan 29, 2016 07:37 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
