sprocket???
Old Aug 24, 2005 | 01:01 PM
94sport400L's Avatar
Default sprocket???
I have a 94 sport 400L and am replacing the sprockets and chain(2wd). Will there be a big difference if i go from a 12t to a 13t sprocket in front? I know stock is 12/34 right? I really dont want to lose any low end power.
Old Aug 24, 2005 | 01:46 PM
POLARISFREAK's Avatar
Default sprocket???
If your sport is pretty much stock then I'd stay with the 12 front. If you have a pipe and clutch kit then I might go with the 13t.
Old Aug 24, 2005 | 02:02 PM
Fixitmatt's Avatar
Default sprocket???
I don't think it will hurt it too much, as a matter of fact the tranny will fix the difference, what i mean is the tranny will relate the new gear ratio and the difference can only effect the way the tranny works,I have changed sprockets many times and sometimes i never felt or seen any differance. the worst thing that can happen is you may have to change weights in the clutch but i dout that.
Old Aug 24, 2005 | 02:44 PM
conig's Avatar
Default sprocket???
When I went to a 12 tooth front sprocket on my scrambler 400 2x4 from a 13 tooth, I didn;t notice any difference, but the GPS showed a slight 2 mph loss in top end speed.
Has anyone ran a 14tooth sprocket? Is there a huge loose in acceleration? not trying to hijack your post.
Old Aug 24, 2005 | 02:58 PM
Fixitmatt's Avatar
Default sprocket???
with my race mod i went from a 13 to a 15 and didn't lose anything
Old Aug 24, 2005 | 08:14 PM
Default sprocket???
Thanks for the info guys...I just want to make sure that it wouldnt cause any problems elsewhere
if i went to a 13t sprocket.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
