425 Mag will not come out of 4x4 mode
Old Aug 26, 2005 | 05:13 PM
tprice's Avatar
Default 425 Mag will not come out of 4x4 mode
I have a 97 425 mag and just had the cv axle replaced and while trying it out today I noticed that it does not come out of 4x4 mode. It runs fine but whether I have the 4x4 button engaged or not the front wheels lock in when the rear spins. I did the normal back up and all of that and it is fine till the rear wheels start to break loose and then the front locks in again.
Any ideas, I was wondering if maybe the switch could be bad???
Old Aug 26, 2005 | 07:18 PM
ftwflh's Avatar
Sounds like they didnt tighten the hub nut correctly
Old Aug 27, 2005 | 01:21 AM
tprice's Avatar
Could you elaborate on that, thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 27, 2005 | 01:32 AM
ftwflh's Avatar
It needs to be tightened to 18 ft lbs while rolling.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
