200s 200x motor swap
Old Aug 27, 2005 | 11:16 AM
Trikedude's Avatar
Default 200s 200x motor swap
Hello guys, and maybe ladies. I got a 200s thet i have had the cylinder honed out but did'nt have enough money to get a new piston and all. So she ran for the summer good but now shes starting to smoke and I'm trying to find a whole new motor to put in her and was wondering if the 200x motor would fit in my frame, and of course i would need to get a clutch lever. So if any one could help me on the this one it would be appreciated.
Thanks,
trikedude
Old Aug 28, 2005 | 03:12 AM
KNOWSALOT's Avatar
The Facility
The engine is a direct bolt in swap.
The engine will bolt right into the frame and the S exhaust will work just fine, but there are just a couple things you will need to do.
You will need to either use the intake manifold and carb from your S engine setup...or you will have to make an airboot between the airbox and your 200X intake and carb. The X intake puts the carb at a different angle than the S intake.
You can buy a CR dirtbike clutch perch and lever (it has an easier pull ratio) for under $25.00
Then just buy a clutch cable for a 200X. It will be a bit longer than necessary, but not overly so. It will do fine and it will work with the CR lever.
I have swapped S engines into X frames before, but not an X engine into an S frame. You MIGHT have to trim your rear plastic a bit on the sides (not the tire coveragre portion) to clear the kick starter when it is folded out of the way. You will just have to do some measuring there to be sure.
Old Aug 28, 2005 | 09:57 AM
Trikedude's Avatar
Thanks your very much
Old Mar 13, 2006 | 02:09 AM
ERBEDS650's Avatar
I know this is a old thread but that would be a blast to put a automatic in a 200x frame,any one done this before?? can you some how still run the kick starter or only the pull start? heck can ya swap a electrice big red starter on it?
Old Mar 13, 2006 | 02:19 AM
HondaAtcRoxz's Avatar
Yeah ive seen it done before. I went riding the other day and I was fightin with that clutch. I was thinkin of buyin a 200x frame and gettin a 200s motor in it. The frame gets in the way of the electric start and you have to use the pull start witch i prefer anyways.
Old Mar 14, 2006 | 06:27 PM
dellboy's Avatar
hey ive got a 200x with an s engine. no clutch, pull start. jus stripped it and in the process of rebuilding with a few trick bits.
Old Mar 15, 2006 | 11:13 PM
BigRed1985's Avatar
does the 200s engine have close to the same power as the 200x?
Old Mar 16, 2006 | 01:07 AM
200Xjae's Avatar
If I remember correctly the 200X has roughly 1 more hp.
Old Mar 16, 2006 | 10:48 AM
Trikedude's Avatar
Actually the 200s and the 200x have completely the same top ends except for the 86-87 200x's which the s motor won't work in. Therefore the 200s and x have the same hp.
Old Mar 16, 2006 | 11:08 AM
ERBEDS650's Avatar
So here I go e baying for a 200S bottome end.
