110 atc
You didn't mention what year model 110 you have.........
It will work if it's a 1981-1985 ATC 110 with the stock CDI ignition.
The older 110 models with the 6V points ignition will accept a coil from the later 110 or any other 12V setup, but they usually don't last but a short time. They don't mate together as designed and overheat.....eventually failing.
