clutch weights and spring and rejetting
Old Aug 30, 2005 | 03:33 AM
kingdog's Avatar
Default clutch weights and spring and rejetting
Hi guys. My 2004 prairie states in the manual that clutch weights and spring should be changed at anything above 1600 feet sealevel. Has anyone had to lean main jets and change weights and spring to get good performance,I live in Medicine Hat , Alberta Canada at 2350 feet above sealevel.Bike surges at 95 kms hour and won't go much faster.Also backfires on decelleration.My buddies 650 Rincon can just about keep up with me and I thought a 650 prarie could take one of those at top speed.I also have the dyna cdi installed and have a good increase in bottom end(wheelies) but it also backfired on decelleration with stock cdi but would go 98Kms hour without surging.Installed dyna because belt limp mode would activate without tripping switch very frequently (bad cdi?).I hope someone can help me with this. what's your top speed with your stock bikes.Is mine slow? Thanks in advance for your help.
Old Aug 30, 2005 | 08:39 PM
HughJazz's Avatar
You can try putting in a dyna jet kit. They rejet for different altitudes. I wouldn't change the springs or weights unless you have put bigger/heavier tires on.
ghost civic
Jan 15, 2020 07:43 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
mitchxc700
Aug 19, 2015 02:41 AM
