did my bearing carrier shat the bed?
Old Sep 4, 2005 | 05:27 PM
emac's Avatar
Default did my bearing carrier shat the bed?
i noticed yesterday that my axle was moving all around and getting really sloppy. i can see right into the carrier on the sproket side and i dont know if it has something to do with the locknut on the brake side. im almost possitive the bearings are gone.
can some1 tell me how to get my axle out to see whats rong.
any other help would be apreciated also
Old Sep 4, 2005 | 06:31 PM
tprender's Avatar
You have to take the hub off and axle nuts off on the right side(brake side). The axle might then come out. Most likly you will need a new bearing carrier and maybe an axle also. It is better to go an buy an aftermarket twin bearing carrier instead of the stock one. If you should need an axle, I have a used one that is good that I need to get rid of.
Old Sep 5, 2005 | 01:08 AM
emac's Avatar
thanx, ill take it apart tomoro and let you know if ill need the axle.
Is yours stock and how much $
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
