diamondtrak or mohawks
Old Sep 5, 2005 | 12:03 AM
ridennraptor's Avatar
Default diamondtrak or mohawks
Will the AMS diamondtraks work as well as the mohawks?
Old Sep 5, 2005 | 12:09 AM
NEWDUCK's Avatar
i cant help you out there but just wondering can you goall the way up banshee hill with out a problem?
Old Sep 5, 2005 | 12:13 AM
On my raptor it goes up fine. I put it in 3rd gear and most of the time it will go up fine. Sometimes i have to shift into 2nd. But i will make it up almost everytime. when i dont it is not the bikes fault.
Old Sep 5, 2005 | 12:14 AM
NEWDUCK's Avatar
hmm sounds like banshee hill isnt much of a hill then.
Old Sep 5, 2005 | 12:15 AM
not to bad. Stock blasters will make it up most of the time.
Old Sep 5, 2005 | 12:16 AM
My dads grizzly will only make it up some of the time though. Only in wet sand. Wont make it up in dry.
Old Sep 5, 2005 | 12:20 AM
do you ride in sand much?
Old Sep 5, 2005 | 12:45 AM
NEWDUCK's Avatar
wow if a stock blaster can make it up my lakota should fly up it. I ride at St-anthony and Little sahara/sand mountain in Utah. Im probally in the sand 5 times a year
Old Sep 5, 2005 | 01:22 AM
A stock blaster probably won't make it up. It would need a jet and/or a pipe and paddles. Do you use paddle tires in the sand?
Old Sep 5, 2005 | 01:23 AM
NEWDUCK's Avatar
Yes i use paddle tires they are the only way to go. I tried using some aggressive mud tires but they are to heavy and dont spin as fast as the paddles do
