hybrid 70cc miniquad
Old Sep 5, 2005 | 09:09 AM
ltdaddyo's Avatar
Default hybrid 70cc miniquad
hello everyone. Iam building my daughter a blaster hybrid ,does anyone have any info,pics or specs that I can obtain to help in the building process.ie:size shocks frame fabrication, rims ,tires,gearing,exhaust,I have a crate honda cr 80 motor to run it.. any help would be super helpful !!!!!!! thanks
Old Sep 5, 2005 | 11:23 AM
LT80's Avatar
LT80 Expert
The only tricky part is getting the sprocket shaft on the motor to line up with the back sprocket.
You will have to grind the lower motor mount on the CR motor. This is when you will take the alignment into consideration.
The rest was easy. Welded a cpl other motor mounts on and a cpl tabs for the radiator. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 5, 2005 | 11:46 AM
ltdaddyo's Avatar
thanks lt.by the way changed the sproket back to a 10 per our conversation and what a dramatic difference!!!!!!! thanks again re:lt80 gearing
Old Sep 5, 2005 | 01:35 PM
bigdumbfun's Avatar
I probably can't help you out here....but you got my curiousity aroused. What is a blaster hybrid?
Old Sep 5, 2005 | 03:08 PM
ltdaddyo's Avatar
Its a yamaha blaster frame customized to fit a 80 cc dirt bike engine using honda 90 plastic and smaller shocks to lower it. if built right,it is an awesome motocross racer with excellent stability,and nice power..
Old Sep 5, 2005 | 03:15 PM
bigdumbfun's Avatar
sounds pretty cool. You will post pics of this when you're done I hope?
Old Sep 5, 2005 | 03:33 PM
ltdaddyo's Avatar
shure.. Ill keep posts through the building process.
Old Sep 5, 2005 | 05:23 PM
LT80's Avatar
LT80 Expert
hmmm,,why call it a 70? It's a 90cc modified (according to ATVA standards). [img]i/expressions/face-icon-small-happy.gif[/img]
Usually the stock or better shocks are used, not shorter.
And why not the blaster plastic?
Just curious. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 5, 2005 | 08:31 PM
ltdaddyo's Avatar
well, that is just based on bits an peices I got from a few people .my main concern is the higher stance I dont know anything to do about lowering it or the tire and rim sizes. any help on that would appricated. thanks for the input.
Old Sep 8, 2005 | 01:07 AM
honyam's Avatar
The one I made for my son. New motor mounts on the front also a mount on the bottom, We had to cut into the left side of the swingarm to line up the sprocket. We used the swingarm bolt too through cr80 motor. Don't push the motor forward. We used a 250r radiator,had a new rear sprocket made for a 428 chain I went with a 49tooth. Used a 250r clutch cable. Cut the pipe and rewelded to fit. Alot of little thing had to be done.
Im very happy with the project and glad I did it. It's faster than the stock blaster. I have pic if you need
