440ex w/12:1 piston question
Old Sep 9, 2005 | 03:44 AM
AustinONeal's Avatar
Default 440ex w/12:1 piston question
Buddy just got a 440 with 12:1 piston installed and when he gets it into a higher rpm it sounds like the valves are hitting the piston. he took it to the honda shop that put it in and they said it was out or time, so they adjusted the valves and got it in time, it was still tapping when he got it bac, he took it back and then they said it was a leak in the head they put a new gasket on and it still makes the noise, they then supposed to have tore it completely down and checked everything and it still makes the noise.
It doesnt do it at low rpm if you romp on it pretty good it will start maing noise, i mean its the most sickening sound's like you got 2 welding rods beating on a peice of steel
Figured all you honda guru's could help him out, he would appreciate it alot.
Old Sep 9, 2005 | 04:00 AM
TNTQuadJunkies's Avatar
Are you sure its not the Cam??? What kit do you have in it?? Ive never had anything go wrong with mine, but when I had a defective Cam it madea banign noice sorta(hard to explain) and it was the older style Hot Cam that they changed, once I change that it was fine .
Im not much help, but I do run the 12:1 as well. Good luck
Tina
Old Sep 9, 2005 | 06:27 AM
he has the stock cam, but for the kit he just went in there and they punched it out to a 440 and put a high comp piston it.
and its 12.5:1 if that makes any difference
Old Sep 9, 2005 | 09:38 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Well I doubt the leak is making the noises your talking about. It could be your timing chain, if the tensioner isn't adjusted properly then you chain could be slapping around or maybe even jumping time.
Old Sep 9, 2005 | 12:50 PM
that could be it (just talked to Bob craycraft and thats one of the things he mentioned) also he said maybe the piston is in backwards anyone got anymore ideas?
thanks
cornermike
Sep 10, 2015 08:30 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
atvcollector
Sep 8, 2015 05:11 PM
Jason Richards
Sep 4, 2015 06:17 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
