wow did i F*ck up
i was changing the gear oil in the rear end of my 300 4x4 and everything was going fine until i used my POS torque wrench to tighten the drain bolt to 9 ft/lbs since my torque wrench is f'd up i over tightened the bolt and snaped the head off luckily its a real clean snap off i really dont want to drill and tap another hole does anyone have any ideas on how i can get the bolt out????????????
please advise!
please advise!
go get a set of "easy outs"...............drill it and use the easy out...
If it is still sticking out slightly, you can try some vise-grips
I have to ask.......................WHAT WERE YOU THINKING??????????? 9 ft/lbs is just a touch over hand tight; you had to be WAY over that to snap that bolt!.......not raggin' on ya, just asking!
Same think happened to myself on my recon which has the same drain bolt.
I was able to take a small screw driver and with slight pressure back what was left of the bolt out.
I think mine had to much pressure put on it at the factory because mine twisted right off when I went to change the fluid.
Start with a left handed drill bit, or a reverse drill ( same thing diffent name......... ) Then if that doesn't work go buy you an easy out and pound it in there good then put a vice grip on her and see if you can get her out, put some WD or PB blaster on it for some lube it might come out easy.....
they also have kits where you drill and hole and stick in a special bit which spins it out. sorry, but i cant remember the name
