which oil? Honda GN-4?
Old Sep 11, 2005 | 08:05 PM
beenmuddin71's Avatar
Default which oil? Honda GN-4?
Which oil is best for a 04 Kodiak 450? The Yamaha dealer told me to use Honda GN-4. He said thats what they put in them when they service them. But i was wondering if its ok to use like regular Castrol motor oil.. its cheaper and I was told it has the same specs that the Honda GN-4 has.. and its just your buying the name and your getting it from the dealer so its more $$?? Ive been using Honda GN-4 in it since it was new, so should i just stick with it and pay the few extra dollars? Does anyone have any info on what oil they use or recommend using?
Old Sep 11, 2005 | 08:15 PM
keelam's Avatar
if it has the same specs, then why spend the extra money for no reason?
Old Sep 11, 2005 | 08:28 PM
recon99's Avatar
You can not use automotive oil in a quad. It will cause the clutch to slip because of the additives in it. I use Valvoline atv oil in my warrior which I get at autozone for 319 a quart, you can use any oil made for atv's or you can use oil for motorcycles, but just don't use oil for cars you'll end up spending a lot more repairing the damage it caused than you will save by using cheap oil.
Old Sep 12, 2005 | 10:30 AM
ddrumman2004's Avatar
Just make sure that the oil you buy does NOT have "Energy Conserving" in the spec circle on the back of the bottle. I used Castrol GTX in my 95 Kodiak that I used to own and it was not energy conserving.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
