Quazi 110 electrical problem
Old Sep 12, 2005 | 08:15 AM
made4speed2's Avatar
Default Quazi 110 electrical problem
[img]i/expressions/face-icon-small-disgusted.gif[/img]
My son was recently riding when suddenly the bike went dead. i noticed that his rear brake light remained on. The bike will not start and seems to just be "clicking" from the ignition coil. I did find the problem with the brake light. the wire came out of the left side handle bar. can anyone help with this electrical problem. Is it the ignition coil or am I just missing something small. thank you for any help you can provide. SAD SON!
Old Sep 12, 2005 | 09:29 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would think the loose wire had something to do with it going dead. Im thinking that loose wire was part of the brake switch that will keep the quad from starting if the brake isnt pulled in. And welcome to the forum made4speed2.
Old Sep 12, 2005 | 10:38 AM
Old Sep 12, 2005 | 10:41 AM
Thank you. Im thinking it is something simple also. I have pulled all the plastic off and traced the wiring and can't find a thing. It has to be something stupid that I'm missing. The bike only has about 20 hours on it and has ran great until this point.
Old Sep 14, 2005 | 01:20 PM
Nuker's Avatar
First slowly recharge your battery. Does the brake light stay on when quad key is on? Either disconnect the plug (easiest) close to the brake light, or take the brake lever off the handlebar and check the plunger on the wire going to the inside of the brake lever. It should be pushed in when not applying the brake and it is allowed to move out when you pull the brake lever. (it's an easy fix, that's where my son's was broke) Also check behind the brake pedal but in front of the rear tire, there is a spring and plunger assembly that may be stuck and is holding the brake light on. Good luck
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
