05" KFX80/LT80 jetting help
Old Sep 18, 2005 | 01:00 PM
kfx400kawasaki's Avatar
Default 05" KFX80/LT80 jetting help
My friend wants me to jet his son's 80 because he installed a FMF Gold seiries pipe on it. I was wondering if anyone could give me instructions to changing the main and pilot jets and moveing the needle? Is it the same as you would on a dirtbike or YFZ450; take off the 17mm nut on the bottom of the carb and the jets are rite their? Is the needle accesed through the top of the carb?
In other words please post step by step instructions on how to jet a KFX80.
Old Sep 19, 2005 | 12:09 PM
LT80's Avatar
LT80 Expert
You must remove the carb and take the 4 screws out to remove the bowl. No big hole like other carbs.
Yes the needle is accessed the same as others.
Why does it need a jetting change? What's the plug look like?
FYI: they come jetted very fat. To rejet you will go DOWN in jet size. Prolly a 87.5 or 90 will do it.
Old Sep 19, 2005 | 11:33 PM
I'm at about 4000ft.
do they have pilot jets also?
What is the stock main?
I have not seen the plug but he said it idles ruff or does not idle at all.
Do I need to change the needle clip position?
Thanks for all of your help.
Old Sep 20, 2005 | 02:41 PM
LT80's Avatar
LT80 Expert
Yes they have pilot jets. The stock pilot is either 17.5 or 20. Stock main is 92.5
I wonder if all that is needed is the idle screw turned in?!
Your welcome. Happy to help. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 22, 2005 | 01:14 AM
duneaholic's Avatar
I'm close in elevation to you and I went with a 87.5. I didn't mess with anything else other than the main jet.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
