trailblazer starter removel
Old Sep 18, 2005 | 06:27 PM
ragged63's Avatar
Default trailblazer starter removel
I removed the two bolts inside the pull start hud the lower one on the back side of the starter, but I can't get to the upper one. Does the clutch cover and clutch or trans have tp be removed to get to the other bolt. Any help would be great, wife's bike and she is getting mad. eant's to ride, thanks Louis
Old Sep 18, 2005 | 10:41 PM
ragged63's Avatar
anyone, Please
Old Sep 18, 2005 | 10:48 PM
trailblazermudrunner's Avatar
yes you do have to remove the clutches to get to the top bolt
Old Sep 18, 2005 | 10:50 PM
rieds's Avatar
the easyest way is to remove the clutch cover, both clutches and the back cover, but you need a clutch puller to get the primary clutch off. before i changed my motor mounts and realised how easy it would be to do it that way i pulled the clutch cover, remove the secondary clutch, take the three bolts holding the back clutch cover on out, take the bolt that goes thru the back clutch cover and into a tab on the frame out, then you can pull the back clutch cover out rotate it a couple inches and rest it on the input shaft that you took the secondary clutch off of. some people can do it without messin with the clutch housing at all. i don't know how but i've heard it can be done.
Old Sep 18, 2005 | 10:57 PM
cornbread2's Avatar
All you need is an offset 10mm wench.
You don't have to pull the cover if you have the right tools.
Old Sep 18, 2005 | 11:32 PM
rieds's Avatar
hey cornbread2, for future reference what is an off set 10mm wrench? i can't picture it in my head.
Old Sep 20, 2005 | 09:13 PM
ragged63's Avatar
got the starter out, thanks for all the help. Starter completely rusted, buying a new one on e bay.
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
