Sportsman starter repair
Old Sep 18, 2005 | 08:53 PM
sammydogs64's Avatar
Default Sportsman starter repair
Hi Guy's, my buddie has a 2002 sportsman 400, and he is having a couple of problems. First the starter makes a spinning noise but does not engage, I assume the starter clutch/drive is bad, is its possible to remove clean grease and reasemble or does he have to buy a new starter and drive? Second he has a real hard time getting it into gear, not certain if its forward or reverse but is that usually and adjustment? He does not have much cash so I am looking for the least expensive fix to make it through the winter as his wife is pregnant and she has to plow his driveway with this when it snows.
Thanks for your help.
Regards
Don
Old Sep 21, 2005 | 10:24 PM
All I can say is WOW! You Slowaris guy's are really helpful! I have never not received a reply on a question on the Kawasaki, Suzuki or Honda forums.
I cannot believe the lack of help, you guy's are great.
Old Sep 22, 2005 | 03:42 PM
Headsledracing's Avatar
Starter drive bendix is separate from starter motor and can be bought separately.On my 2-smoke 400 you just remove recoil, flywheel and its right there.Never worked on 4-stroke though.My first post ,couldn't have ya callin down the "P" boys!
Steve
HEADSLEDRACING
Old Sep 22, 2005 | 03:44 PM
On the shifting thing just a guess but maybe lower idle speed,sqeeze brake when shifting and lube all linkages?
Steve
Old Sep 22, 2005 | 04:09 PM
Thanks for the reply Steve
Old Sep 24, 2005 | 10:37 AM
Andre's Avatar
Whaz up Dog?
A search on this forum will answer 99% of the questions your buddie my have and you won't have to wait on us Slowaris guys for help.
Old Sep 25, 2005 | 03:34 PM
bambihunter's Avatar
you should only have to remove starter, disassemble,clean and lube gear sparingly. there is not much room to get to the bottom starter bolt but there is enough. do not forget to put bottom bolt through starter before reassembly.
ghost civic
Jan 15, 2020 07:43 AM
Sandman2.0
Jul 21, 2015 09:03 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
