tieing down the bike
Old Sep 20, 2005 | 11:56 PM
workaholic's Avatar
Default tieing down the bike
Can I use my wench cable to tie the front end of my sp-500 to the front of my car hauler trailer?
If I pull it down to far can I damage the front struts on the ATV?
I typicaly use two tie down straps in the back.
Thanks
Old Sep 21, 2005 | 12:01 AM
Bretman's Avatar
i am not sure on that dude, i would just go and use ratchet straps, you cant go wrong with them. Go to walmart and you can get like a 4 pack for like $20 or less. You cant go wrong.
NewD10's Avatar
i use straps all around. ive heard people using the winch but i dont like too, i think does pull down too much on front end. maybe good for a safety in case the straps fail.
Old Sep 21, 2005 | 12:48 AM
workaholic's Avatar
I was hoping I didn't pull the front down to far when I loaded it last nite.
Is there an easy test for damaged struts?
The rubber stops were almost topped out when I looked at it today
Its new, Im still like a new papa
thanks
Old Sep 21, 2005 | 01:03 AM
okiedude's Avatar
I use straps....but I do use my winch as a "emergency" backup. I dont cinch it down so much that it pulls the front end down that much though.
Old Sep 21, 2005 | 08:23 AM
scootergptx's Avatar
Supersock
Hired Gun!
I tie mine down on the frame. Use 4 straps crossing front to back. Never had a problem yet. I do buy new straps every year (have lots of spares now). I figure 20 bucks every year is worth the extra insurance knowing my straps aren't worn out and barely hanging on.
Old Sep 21, 2005 | 11:04 AM
hudson4269's Avatar
I bought four 8ft ratchet straps at walmart for $15.
I wouldnt risk damaging a bike that cost thousands or a winch that costs hundreds over $15 tie downs.
Old Sep 21, 2005 | 11:20 AM
Sluggo312's Avatar
I'm like Okiedude. I strap the quad down as if I wasn't using the winch (one strap in each corner b/c I'm **** about it) then I attach the winch as a backup. The winch is only tight enough to take the slack out of the cable not enough to pull the quad down or loosen the straps.
Customer Service #1
May 15, 2020 08:46 AM
meddy0388
Sep 9, 2015 06:41 AM
89Lt250r
Sep 7, 2015 07:53 PM
lancemll88
Sep 6, 2015 03:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
