what is top speed on stock trailblazer 250??
Originally posted by: MnFriesen
50ish
50ish
I've GPSed my Trailblazer at about 43 on hard pack dirt with low pressure in the tires (3psi). About 47 with 7 psi in the front and 5 psi in the rear on hard pack dirt (this is the pressure I normally ride with). In soft level sand, I GPSed just over 25 in sand without sand tires. About the same with only rear paddles. And 37 mph with paddles in the rear and sand tires in the front. The Trailblazer needs front sand tires to effectively ride in the sand because the front end digs with stock tires.
I hope this helps you
BryceGTX
BryceGTX
that is on a gravel road, had the 700 running next to it so it is a good estimate. and I am not the had a friend of mine runnin the trailblazer while I was on the sportsman so I could see the spedo...he said he had it pegged... probably gained a little top end now that we had it rebuilt...
